Old 04-30-2008, 08:45 PM
fordsd350 fordsd350 is offline
4-pin mini DIN pinout?????
I have a Power Acoustik LCD monitor that has a 4-pin mini DIN connector and I'm trying to determine the pinout for the connector. Any help would be greatly appreciated!!!
Old 04-30-2008, 10:33 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: 4-pin mini DIN pinout?????
it doesn't tell you in the manual that came with it ?
Old 05-01-2008, 02:41 AM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Usually the connector plugs into an extension that should have come with the monitor, the extension usually has the video input, and the transformer wired into it. I will check to see the amount of pins on one of mine tomorrow.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 05-01-2008, 08:41 AM
Audio Guy
ok, I have to admit I have VERY little experience with video stuff.
Old 05-01-2008, 06:56 PM
I bought this new/used from ebay with the knowledge that it was incomplete. I think I will just buy a 4 pin DIN and build my own. All I really should need is a red/black for power and a RCA for the video - right?
I'm not exactly a low voltage guy, but current should be the same no matter the voltage. It's usually easier finding your mistakes with 4kV.
Old 05-01-2008, 07:00 PM
Hey, thanks in advance for looking. I'll probably breakdown and simply pull it apart as I should be able to easily ohm it out.
The manual came in English, but beyond that it's pretty useless.
Old 05-01-2008, 11:48 PM
Audio Guy
truthfully, most of them are nowadays ..... nothing more than a mareketing hype sheet
