Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-30-2008, 08:09 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
different compression readings
Ok so last year I did a compression test on the GSX and came up with some pretty weird numbers. I don't really remember what they were, but they were completely different from what I made today, and I haven't made one change to the engine internals since.
So I got the engine to operating temp, and cranked it with the throttle plate opened and this is what I got
from Left to Right as your looking at the valve cover from the front.
160,150,190,195
The car runs fine and boosts strong, no burning oil, no oil in coolant and vice versa. I didn't do a wet compression test yet, but I read that there is a problem if there is more than a 15 psi gap between cylinders. I also read that if there are two cylinders next to each other that are considerably lower to the others, then there could be a leak in the head gasket causing compression to leak from one cylinder to the next.
Anybody care to fill me in or give me some suggestions as to whats up with cylinders 4 and 3?
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
