Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 04-30-2008, 01:02 PM
D-Ro D-Ro is offline
2003 Eclipse GTS- suspension problem?
When I drive my Eclipse, after about 10 minutes of driving a sound starts to come from the front of my car whenever I go over a bump. It sounds like a creaking noise.
This sound is also reproduced when I turn my wheel at a stop. Or when I get out of my car after a trip and push the front of the car down.
The sound is NOT produced until I use it for a little bit, so when I get in my car in the morning and turn the wheel or go over slight bumps, no creaking sound is produced.
Thoughts on what this might be?
Just replaced my clutch and not excited to put any more money into it. It's not a problem right now, but I don't want it to become one in the future, and I plan to take it on a road trip to CO (from WI) in July, so I want to make sure everything is in working order.
Old 04-30-2008, 03:00 PM
808drifter 808drifter is offline
Re: 2003 Eclipse GTS- suspension problem?
Might just be your springs.
Maybe frnt swaybar bushings need to be greased?
Old 05-24-2008, 07:52 PM
jay510's Avatar
jay510 jay510 is offline
i had some shit like that happen to me but i thought it was my stock springs so i swaped those out with teins, but the sound was still there...took it to this evan's tires place and they found my problem....it was the left motor mount. the rubber was cracked....so i replaced both motor mounts.....my total for the whole thing was around 300$ they installed it fast...if i was you i would check those with a flash light and if it is cracked just go on google and buy you the performance motor mounts....there cheaper and beter and you or a buddy can install together .....if you dont got buddies then take it to a shop where they do it.....all you might have to do is pay for labor....its like 40$
2003 eclipse GT spyder v6
MoDs:
evo catback exhaust
K&N Cold Air Intake
20'' crome & black rims
Tein lowering springs 3''
Alumn Radiator...in progress, to lazy to do it.....
projector headlight black
removed rear wing
window tint black
x2 12' audioban subs
more to come......
supercharger coming soon after my performance headers
Old 05-25-2008, 11:00 PM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
there are actually 4 motor mounts....just fyi
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 05-26-2008, 09:28 AM
Yah but those POS ones on the sides always go.
Old 05-31-2008, 04:12 PM
jay510's Avatar
i know theres a front and rear but those dont sqeek, only the left and right ones sound like your susp. is going out .the front and rear only make the engine rock back and foward, and trust me after installing a new engine my front ones were cracked and i replace that....
MoDs:
evo catback exhaust
K&N Cold Air Intake
removed rear wing
window tint black
more to come......
Old 07-14-2008, 10:07 PM
Update:
The sound magically went away... so I figured I'd let it go until they came back again- sure enough another rain storm and they started the squeaking.
I rotated my tires and noticed that it no longer comes from the front left, instead now it sounds like the back left (where the front left tire was rotated to). Not really sure wtf is going on... going to check out the motor mounts though, seems like a couple people had the same problem.
Old 07-15-2008, 12:35 AM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
do you think it may be a tire? tires can make funny noises when they start coming apart and they heat up after driving for a bit. did you hit any potholes? what brand of tire are you running.
Don't act like you don't love it.
503/2000
Old 07-26-2008, 01:07 AM
That's what I started to think about now that I rotated the tires and it's making a funny noise- but I was thinking it may be the rim?
WI had a REALLY tough winter this last year and as a result more potholes than I've ever seen in my life. So yes, there have been pot holes. No one that stands out as a "oh !@#$".
The noise happens when the car seems to rock forward/backward (so when I stop or start) and also when it bounces up and down (over a bump, or when I push on it). Not really sure. I'm thinking of switching the tires again and seeing if the sound moves with it.
The tires are practicaly brand new- only about 6,000 miles and 7 months of use on them. Not sure the brand, I have to double check
Old 08-16-2008, 04:08 AM
perna00's Avatar
perna00 perna00 is offline
Send a message via AIM to perna00
Could just be the sound of metal on metal from the springs. When it's the morning, you got condensation from the night lining them with water quieting them. Just a thought though. After it starts making that noise, spray different parts with water and see if it quiets; you'll also see what parts the noise is coming from too.
