Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Bolt on Parts
Old 04-30-2008, 12:43 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question Oil Tap and WG
Alright quick question here. On turbo oil return lines, they all go to the oil pan. I have one of those oil sandwich adapters... can I run a return straight to there instead of welding in a bung in the oil pan? It's the same place anyways.
And it's not good to run the oil feed line from those adapters right? Can cause too much pressure?
Then for an WG if someone were just dumping it below the car, how far down would it have to be in order to not affect engine bay temps? You figure you run the dump tube down and then just drop it, but the heat from the exhaust will rise right back into the bay and into the filter if it's right there. Or would it be better to get a housing where the WG goes right into the exhaust?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 04-30-2008, 01:46 PM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Re: Oil Tap and WG
Are you piecing together a turbo Dave?
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 04-30-2008, 01:59 PM
david-b's Avatar
Dave is THAT guy
Re: Oil Tap and WG
no.
75 Monte Carlo
Old 04-30-2008, 03:27 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Re: Oil Tap and WG
dump it, mines dumped, that the pipe is about 2" short from hanging below the body... basically, 2" above the frame... lol if that make since?
Old 04-30-2008, 06:54 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Oil Tap and WG
You run the oil feed line from the back of the block where the oil pressure sending unit is. I guess you could run it from the sandwhich adapter also but I have never heard of anyone doing it. On a MHI turbo you dont need to worry about oil pressure because those turbos have built in restrictors. On any other turbo you will need to put a restrictor inline with the feed line.
I have my wastegate dumping right in front of the tranny. It is about even with the bottom of the motor, maybe a little higher but it wont hurt anything.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 05-01-2008, 10:26 AM
david-b's Avatar
Dave is THAT guy
Re: Oil Tap and WG
Are the restrictors those little plates that are right up on the turbo that have like a pin-sized hole?
75 Monte Carlo
Old 05-01-2008, 12:19 PM
Holset powered 420a
Re: Oil Tap and WG
Yea that should be a restrictor. Some actually screw inline with the feed line but either one will work fine. Just make sure you have the right size hole in there. I beleive there is different size holes depending on how much oil pressure you are getting.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 05-01-2008, 03:58 PM
JoeShmoe's Avatar
Re: Oil Tap and WG
whats the diff in dumping in and out of the exhaust?
Old 05-01-2008, 09:12 PM
Holset powered 420a
Re: Oil Tap and WG
There is no difference in performance. The only difference is whether the wastegate dumps right under the motor or back into the exhaust.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 05-01-2008, 11:35 PM
david-b's Avatar
Dave is THAT guy
Re: Oil Tap and WG
The only difference I can see is dumping close to the engine causes more heat build up, thus sacrificing performance. That's why you run it out the side of the bumper in front of the front wheel. SEXY!
75 Monte Carlo
Old 05-02-2008, 09:56 AM
Holset powered 420a
Re: Oil Tap and WG
By the time the wastegate opens your already moving, I doubt it would raise the underhood temps at all.
98 Eclipse GS Turbo
2001 BMW 325i - DD
