2000 Trooper Front Disk Removal
I need to have my front brake disks turned. I read the article in PLanetisuzu on repacking the front wheel bearings; are these applicable to a 2000 4WD Trooper?
I couldn't find the referenced NAPA part number for the hub nut tool (NAPA Tool # 3375 / Isuzu Part # J-36827) in the online NAPA catalog. Any suggestions on where to find this tool? Thanks much. |
Re: 2000 Trooper Front Disk Removal
//bc
1992 trooper 3.2L v6 sohc automatic...as is i love a good intermittent electrical challenge. . .especially when it's someone else's. |
Right, you can tap the nut off/on w/a hammer and drift or chisel.
Also, leave the rotor mounted to the hub. IIRC, I pulled it off, then the machine shop said it had to be mounted on the hub for this particular application.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs 80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ... 89 4Runner - stock 2000 Isuzu Trooper + 2010 Sonata |
Just to let other Trooper-owners know, I pulled the rotors off the front wheels this weekend and had them turned. I followed the instructions posted in Planetisuzoo and all went very well.
The snap ring pliers, the spring scale, and the dental pick are must-haves, but not the hub nut tool. The hub nut came off pretty easily using a round chisel and a hammer. Not counting the time to have the rotors turned at O'Reilly's, I spent about four hours from start to clean-up; and I hand packed the bearings.The intructions really helped keep me on track. BTW, I have about 170k miles on this 2000 Trooper and this is the first bearing job I've done-the bearings looked to be in great shape, but the grease did need to be changed. Also, I changed the fuel filter - a breeze; took maybe 10 minutes total. Thanks so much for all the help! |
