Go Back   Automotive Forums Car Chat > Pontiac > Grand AM > Tips and Maintenance
Tips and Maintenance Post helpful tips, maintenance guides and R&R procedures here
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 04-29-2008, 10:18 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Thumbs up Flushing Your Power Steering System
* You will need several quarts of power steering fluid, cheaper brands can be used for flushing, though a high quality GM approved fluid should be used when refilling.
You will need a large plastic container(old oil jug would work) to drain the oil fluid into.
You will need a long hose, 5-6 ft, pex tubing works well so you can see when the fluid runs clear , and a fitting of sorts to attach this hose to the low pressure line.
Should look something like this, but with a clamp where the red arrow is.
Obviously you can use any tubing, clear works best to see when it runs clear.
- For best flushing results the system should be flushed with seafoam trans/power steering flush or something simular. http://www.seafoamsales.com/transTuneTech.htm
- I usualy use about 1/2 the can(6 oz) before replacing pumps and R&P's, hoses also should be replaced if those were replaced(so you dont ruin more good parts & void warranties).
-- Flushing The System
- Attach the flush tubing to the low pressure hose , the smaller hose without the plastic protecter. Might need a clamp on the flush hose or low pressure hose if your fitting is to loose.
- Drop the other end into an old container.
- Something like this...
- Have 2-3 quarts of new power steering fluid ready.
- Begin to run the engine, slowly add the fluid into the reservour, trying not to let it run dry . It may help to have a helper.
- Reattach the low line to the pump inlet as it was before.
- Then refill the system and add the seafoam(or other brand of cleaner), run it just like the directions state.
- then you drain-flush the system again by attaching the flush hose into the low pressure side, and flush agian with 2-3 more quarts.
- Once the fluid runs clear out the drain into the container, you can refill with approved fluid and begin bleeding the system.
Hope that helps.
1999 Grand Am SS 3.4 OHV
Closed Thread
