Old 04-29-2008, 09:24 PM
DUALLYDREAMER DUALLYDREAMER is offline
454 Headache
I Have A 90 Chevy 1 Ton Dually with a 454 I Changed O2 Sensor, Idle Control, Map, New Fuel Filter, New Fuel Regulator, And Still My Truck Sputters When I Accelerate. Help Please!
Old 04-29-2008, 09:57 PM
Dunamis Dunamis is offline
Re: 454 Headache
Checked your OBD1 (computer) for codes? If you don't have a scanner, you can use a jumper wire.
I have a Haynes manual. I looked under the "Hesitation or Stumble durting Acceleration" section. It says to check the following:
1. Ignition timing incorrect
2. Ignition system not functioning properly
3. Dirty or Clogged fuel injectors
4. Low fuel pressure. Check pump and lines for clogs.
I don't know as much as I would like , but but between my Haynes manual and this board, everything seems to come out in the wash...
Old 04-30-2008, 03:33 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 454 Headache
Check the fuel pressure and spark plugs/wires/cap/rotor.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 04-30-2008, 05:12 PM
Will Help Will Help is offline
Re: 454 Headache
Had similar problem with 78 454 HD. Spark plug wires were failing. Had to go to 8mm wires.
