Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 04-29-2008, 08:39 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Thumbs up O2 sensor
About how ofter should one change the O2 sensor.
My car has 307 vin y engine and about 20k since i last changed it.
The CEL has flashed on a few occasions briefly, then went out when the car was first started in the morning. Other than that, no CEL.
There were no codes stored when i checked.
Thanks for the input
Al
Old 04-29-2008, 08:54 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: O2 sensor
A failing sensor is rare and it is rare that the MIL will come on because of the sensor. More likely, there is an issue with the air/fuel mix and the EGO sensor is relaying this to the computer.
If the engine is not running rich, expect 50k miles out of the typical EGO sensor.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
