Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 04-29-2008, 03:45 AM
projectgsr's Avatar
projectgsr projectgsr is offline
Cylinder head?
Ok, so I finally had the time to torque down my new head gasket today and reinstall my cams. Two questions. First, why is it that almost every forum and source on the net advises to torque down arp head studs to around 70 psi yet when I read the instructions that arp gave me it said to torque the nuts on the studs down to 80 psi with the moly lube? I'll be honest, that does seem a bit too much considering the stock torque is only 63 psi according to my Chilton's manual. Too late though because I already torqued them down to 78 psi and luckly I didn't break any of them
Second question. My Chilton's manual also notes to torque down the camshaft holder's to 20 psi for the fatter bolts and only 8.2 psi for the smaller bolts. That seems very loose to me for some reason. I'm not saying I'm superman but it seemed like I gave those bolts hardly any effort at all. Is that really tight enough to hold the camshafts in place with an engine reving up over 8k? Any help would be well taken. Thanks in advance.
JDM B18C, LSD tranny, Exedy flywheel/clutch, AEM intake, Greddy cat back, stainless header, Skunk2 manifold, Koyo radiator, Tokico Illumina full coilovers, black 17" Konig Hurry's, dc strut bars, custom cf hood, poly motor mounts, alum. battery bracket, b&m short shifter, Viper alarm, spoon chip, Tenzo R seats, Kenwood amp, Pioneer and MTX speakers w/cross over's, euro antenna, NGK wire's and plugs, Mobil 1 syn. and a whole lot of attitude.
9.4 sec 1/8 mile at Irwindale 4/20/06
Old 04-29-2008, 07:34 AM
jclark jclark is offline
Re: Cylinder head?
PSI??????
Do you mean "foot pounds"?? (I hope so)
and not "inch pounds" -big difference.
Also: Make sure your specs are for your engine.
They vary a little by which engine you have.
Jim C.
Old 04-29-2008, 12:36 PM
projectgsr's Avatar
Re: Cylinder head?
[quote=jclark]PSI??????
Yes, of course I did. My bad I wrote this thread at like 1:00 in the morning. I torqued everything down to foot lbs
