Go Back   Automotive Forums .com Car Chat > Oldsmobile > Bravada
Old 04-29-2008, 01:28 AM   #1
mcy00_17
92 Bravada Fuel Regulator
Hello, just bought a 92 Bravada, excellent interior and exterior, however I bought it knowing that the new regulator had to be adjusted..the gentleman had changed the fuel filter and regulator and had told me that I needed a mechanic to adjust the regulator...So I did.....I went to my local mechanic and he did tell me that he has never heard of adjusting the regulator but he tried because the fuel pressure guage was reading 80-86 psi and he told me that it should read 50-60 psi? However after much adjusting both the new and newer regulator he had no luck getting the psi down and he told me that I was looking at spending minimum $500 to get new injector kit from GM....any comments, ideas, or warnings here? Worth fixing or should I sell? I am willing to get my hands dirty, just kind of scared to work on cars..
mcy00_17 is offline   Reply With Quote
Old 04-29-2008, 06:29 PM   #2
Chris Stewart
AF - Advisor
Chris Stewart's Avatar
Re: 92 Bravada Fuel Regulator
Here's a great post on how to replace the regulator & gasket for less than $100.
http://www.automotiveforums.com/vbul...d.php?t=503238
Napa also has a replacement regulator, PN BK7002368
thanks Rilth!!!
Chris Stewart is offline   Reply With Quote
Old 04-30-2008, 12:38 AM   #3
mcy00_17
Thank you, I will try that.
Old 04-30-2008, 09:51 AM   #4
Chris Stewart
AF - Advisor
I went through the procedure myself on my '92 with great results.
Old 05-14-2008, 09:10 PM   #5
old_master
Advisor/Moderator
old_master's Avatar
Have you resolved this issue yet? If this engine is TBI, Z engine code, fuel pressure should be 9 to 13psi. If it is CMFI, W engine code, fuel pressure should be 60 to 66psi. Showing 80 to 86psi with either engine, indicates the fuel return line is restricted.
old_master is offline   Reply With Quote
