| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
fuel pressure regulator
i just bought an aem fpr and i was wondering, do you install it after the fuel filter? i just want to make sure before i do it, because i dont want it to be wrong. thank u
Re: fuel pressure regulator
after the fuel rail.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM. 18 Inch chrome rims In closet AEM Fuel Rail, SS Lines, 1997 TSI AWD Diamonds Are 4Ever 12.7 @ 107 http://i83.photobucket.com/albums/j2...y/DSC00461.jpg |
You install in the stock location, between the fuel rail and the return line.
Not to be a dick, because that is not my aim at all, if you dont know where it should go then you should have help from a friend or have it done by a shop. If it was something that wouldnt have serious repercussions if installed wrong, such as a short throw or a catback, then I'd say use it as a learning experience. However, if you install a FPR wrong there is any number of bad things that can happen such as an engine fire or a mis-set fuel pressure. |
Yea if you set your fuel pressure incorrectly or its not functioning properly you might run very lean and knock your engine out as soon as you hit boost.
i know all about the pressure and where it goes and stuff. its just i bought the FPR off my buddy out of his talon but he wasnt sure if he had it in the right spot so i just wanted to make sure. because i put a bigger fuel pump in so i want to be able to set it at the right pressure when i get a sticker or whatever i do. thanks for the help
wow....
be sure you dont strip the threading for the gauge trying to get it to read right way up... lol... dont ask...
i was wondering, what is the stock fuel pressure? i was just seeing if anyone knew before i brought home the fuel gauge from work. thank u
43.5 psi on 2g
39 1g
43.5 on 1G auto
Tim 1990 Talon AWD 2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink, PTE SCM5031
those psi settings are at 0 pressure (disconnect the vac line from the FPR)
thanks. i got the fpr out of my buddies 95 talon so it is set at 41, i was wondering why it was running richer now. thanks im going to turn it down to 39. and im putting a walbro 255 pump in tomorrow, should i leave the pressure at 39? or go up alittle?
The reason you buy a fpr is so that it can keep the fuel pressure stock even when the fuelpump wants to flow more. Don't increase the pressure.
ok, i just installed the 255 pump and fpr. and i adjusted the pressure to 39 and the car runs great. it runs better then before and sounds more throwty. thanks for ur help, import wars ate new england drag way on june 28th, im going. hope to see some of u up there
