Old 04-28-2008, 08:17 PM
osgusm osgusm is offline
2001 GTP leaking supercharger oil
Just had the supercharger oil replaced on my 2001 Pontiac Grand Prix. After picking up the car I wanted to check the fluids and noticed the supercharger was leaking small amounts of oil from the bolt at the end of the supercharger nose (right at the pulley)
I went back to the dealer hoping the problem could be solved with a gasket or new seal but I was told after 60K miles, the manufacturer recommends the entire unit to be replaced.
My car has 80K miles and I replaced the supercharger oil every 40K miles. The supercharger works fine I don't want to spend 2,000 dollars on a new one when the old one works ok but I'm concerned about the oil leak. The leak is not bad ( a few drops at a time) and it does't leak all the time.
Is the oil leak normal? could I replace the supercharger nose to take care of the problem? I found a link with instructions of how to rebuild the nose drive but it looks involved, Would replacing the nose take care of the oil leak?
Old 04-28-2008, 09:04 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 2001 GTP leaking supercharger oil
Welcome to AF.
The leak is not normal and the dealer is full of bull crap. $2K for a supercharger.
There are repair parts available for the Eaton M90 Gen 3 blower. You can replace the complete snout assembly or simply replace just the snout seal. Repair parts are available at ZZPerformance.com.
Click here
Timeslip 08/12/06
AF Community Guidelines
