Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-28-2008, 09:14 PM
MGNM45 MGNM45 is offline
Dead 1987 5.7 Tpi Camaro
I RECENTLY PUT A NEW TRANSMISSION INTO MY CAMARO AND RIGHT AFTER THE INSTALL THE CAR DEVELOPED A STARTING PROBLEM. IT WOULD TRY TO CRANK ONE TIME BEFORE COMPLETELY DYING ON ME. I WOULD THEN GO UNDER THE HOOD AND PLAY WITH THE POSITIVE BATTERY CABLE UNTIL THE POWER CAME BACK ON. I WENT BACK AND FORTH LIKE THIS FOR ABOUT 20 MINS UNTIL THE CAR FINALLY STARTED. I THEN DICOVERED THAT THE HORN, HEAD LIGHTS, TAIL LIGHTS, BRAKE LIGHTS AND ALL INTERIOR LIGHTS WERE ALL OUT. THE NEXT DAY THE CAR STARTED AGAIN WITH NOT CRANKING. I TRIED WIGGLING THE POSITIVE WIRE AGAIN WHILE A FRIEND TRIED TO CRANK IT AND THEN I HEARD A SIZZLING, BURNING SOUND COMING FROM SOMEWHERE NEAR THE STARTER. NOW THE CAR IS COMPLETELY DEAD AS IF THERE IS NO BATTERY IN IT. THE BATTERY IS BRAND NEW AND HAS A FULL CHARGE SO I KNOW THIS IS NOT THE PROBLEM. IF ANYONE CAN HELP ME SOLVE THIS PROBLEM I WOULD REALLY APPRECIATE IT. tHANKS IN ADVANCE.
Old 05-01-2008, 02:07 PM
Re: Dead 1987 5.7 Tpi Camaro
Anybody? ? ? ? I'm desperate! ! ! !
Old 05-01-2008, 05:14 PM
Morley Morley is offline
First, fix your caps lock.
It sounds like the positive cable shorted against a ground down by the starter.
Disconnect the battery and remove the starter and check it out.
Old 05-13-2008, 11:46 AM
chevyrulespops's Avatar
chevyrulespops chevyrulespops is offline
sounds like the fusible links also took a dive on you because of the short...check those
