Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-28-2008, 03:04 PM
benjammin100 benjammin100 is offline
'99 Camaro random electrical issue
My radio randomly powers on and off while driving. Sometimes it will be off for several minutes (10 - 15) then power back on without me pushing a button on it or anything. I've recently put a brand new battery in the car but still have the same problem. This issue started around the same time my gas gage stopped working and has continued for several months.
Old 05-13-2008, 10:58 AM
chevyrulespops's Avatar
chevyrulespops chevyrulespops is offline
Re: '99 Camaro random electrical issue
I would check the ground wire, could be loose. If I were u I would take out the radio and check the wires leading to the radio. U might just have a faulty radio...is it an aftermarket radio u have installed?
Old 05-22-2008, 04:27 PM
It is aftermarket, but purchased brand new from Best Buy. I had another one in there before that was doing the exact same thing, so I took it out and put in the new one (different brand, purchased brand new) and have had the same issue.
Old 05-23-2008, 05:43 PM
I would have to look at the schematic to get a better idea of how those two circuits are related...I'll try to do some research. The only thing I can think about off the top of my head is that the bose units used to have an amplifier relay wired into the system and if that is failing it would turn off the speakers....an on/ off effect...replace it if you have one...let us know what happened..
Old 05-25-2008, 12:50 AM
Wattsyurz's Avatar
Wattsyurz Wattsyurz is offline
Send a message via Yahoo to Wattsyurz
If slamming the driver's door makes the radio come back on, see the latest 2000 Firebird post. Hope it helps.
'67 Camaro 350 - driver, '83 Z28 305 (off the ECM), and T5
'91 RS 305 T5, 2000 C5 2000 Trans Am
I don't drive the Fords
Old 05-28-2008, 12:01 PM
did u find the cause to that problem???
