Go Back   Automotive Forums Car Chat > Honda > Integra
Old 04-28-2008, 12:25 PM
shadowed eminence shadowed eminence is offline
Cool injector cleaning
I need to clean my injectors, but do not want to take them to a shop as the cheapest shop is asking around $150 to clean them. Does anyone know of any home cleaners or something I can buy to soak them in to clean them out or something I can do other than take them to a shop. Ideas????
'91 LS Integra 4Dr,
warm air intake,
front and rear coilovers,
Phoenix Gold 4Ch 500 watt Amp,
Phoenix Gold front Components
Old 05-01-2008, 12:43 AM
BoostedGSR82 BoostedGSR82 is offline
Re: injector cleaning
I have cleaned mine with some carb cleaner before. Its good at breaking up "goo" that may build up on them. I just sprayed them real good and wiped them off with a clean rag. I have never had any problems doing it that way. Im sure there are many ways to clean them. Who is to say what way is the best? Keep in mind... No matter how you clean them, you will always find someone that thinks their way is better.
Old 05-01-2008, 10:52 AM
thankyou, I appreciate your help
'91 LS Integra 4Dr,
warm air intake,
Old 05-02-2008, 10:33 AM
wiseguy01's Avatar
wiseguy01 wiseguy01 is offline
berrymans 3 step fuel system cleaner at any auto parts store thats what the shop is gonna use
Old 05-02-2008, 10:49 AM
Will Help Will Help is offline
Internal contaminents are the real culprit. Service includes piping cleaner directly into the fuel rail system to clean the internals.
Old 05-09-2008, 10:34 AM
How would I go about doing that??? and what would i use to clean it with (fluids, tools etc)?
'91 LS Integra 4Dr,
warm air intake,
Old 05-09-2008, 01:43 PM
wiseguy01's Avatar
using berrymans 3 step all you would have to do is first step is a spray for the throttlebody fo the butterfly seats correctly second step is you take the vacuum hose off the pcv valve and allow the vacuum of the car suck the fluid into the manifold via vacuum and the third step is to put a cleaner in the tank aka injector cleaner and fuel rail three cans its real easy only tools required are a screwdriver and pliers
Old 05-22-2008, 10:32 AM
I should put all three cans in the tank at once?
'91 LS Integra 4Dr,
warm air intake,
Old 05-22-2008, 03:53 PM
wiseguy01's Avatar
no the can labeled gas tank goes in the gas tank only one can goes in the gas tank the rest go under the hood of the car throttlebody cleaner and the the combustion chamber cleaner
