Old 04-28-2008, 12:32 PM
Dunamis Dunamis is offline
Droplets of "water" in left exhaust pipe???
Today when allowing my truck to idle I noticed that just in the left hand exhaust pipe has drops of liquid coming out of it. I have true dual. That's probably why it only comes out the left side.
Any input as to what this might be?
Old 04-28-2008, 04:50 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Droplets of "water" in left exhaust pipe???
I would guess that it is water. It is normal to have water condense in the exhaust. I have heard that for every gallon of gas burned, there is one gallon of water put out of the exhaust. I don't know if that is true, but there is water that comes out of the exhaust. As long as you aren't losing coolant, I would say it is normal.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 04-28-2008, 07:02 PM
I appreciate the responses!
Old 04-28-2008, 08:25 PM
jveik jveik is offline
yeah water is a natural end-product of combustion, though a lot of water drippage may be bad i suppose because it would indicate a bad head gasket. a lot of cars i follow in traffic will "dump" a little water out the tailpipe when they take off from a stop
