Old 04-26-2008, 09:17 PM
akirmanidis08 akirmanidis08 is offline
94 civic LX stutters
When the car is cold while driving it like to stutter for some reason.
If i push the gas pedal normal i feel the engine bog down. however when i push the pedal all the way it feels like it frees up drives normal. it does this in all gears and only when the car is not fully heated up.
anyone have any suggestions?
Old 04-26-2008, 10:58 PM
wiseguy01's Avatar
wiseguy01 wiseguy01 is offline
Re: 94 civic LX stutters
check plugs and or for a vacuum leak and possible idle air control valve but sounds more like ignition or iacv
Old 04-27-2008, 01:54 PM
the car has just been to the shop last week becuase my coil needed to be replaced. i have new spark plug and new coil now
i also notice that the car is still missing a little about once or twice every 10 seconds.
Old 04-27-2008, 02:28 PM
also i want to point out that my idle is regular at about 700 rpms when the engine is warm and generally i have no idle issues. Only sometimes when im driving and i may come to a stop light or something and the idle is a bit rough. ithe main problem is when im driving and it bogs down like that.
Old 04-29-2008, 02:51 AM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
Did you check the ignition timing?
It's just that easy folks... mind the forum guidelines and we're cool.
Empty Pockets Racing Member #6
EPR Member 4 Life
Old 05-10-2008, 09:44 PM
how do i go about doing that?
Old 05-29-2008, 10:31 PM
95dxcivic's Avatar
95dxcivic 95dxcivic is offline
google
lowered on photoshop(its not that low, its not lowered at all!)
Empty Pockets Racing Member #4
Old 07-16-2008, 08:47 AM
heyyo302 heyyo302 is offline
Did you replace both the coil and the igniter/ICM with OEM parts from the stealership? Usually the stutter is caused by the ICM dying. I've had terrible luck with aftermarket ICMs lately...went through 3, and 2 aftermarket coils before I got mine fixed. Turned out it was a bad coil.
