Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 04-26-2008, 01:05 AM
Bodar Bodar is offline
Biggest hack job
Well this is my first post and its a doozy. i will have pics up tomoro just to prove all this nonsense and hopefully get some help. ok i have a 1985 lebaron gts 4door hatchback. it has a rebuild engine and tranny. i got this thing for free from someone in my family. now stay with me here this is gunna get really messed. It has the 2.2 FI turbo in it, well had. the engine remains, but the manifold has been swapped with a non turbo version. and all lines to the turbo have been pinched. the injectors remain, but on the intake there is a carb.
so the throttle has been changed to work with the positioning sensor on the carb. so it seems the carb only shanges the airflow? i dont know. anyways, the fuelinjected airbox has also been modified to work with this.... as of now the car has 5000 kms on it. it ran fine, then one day it stopped. and has never ran again. so i got it and took it home. it cranks no problem, but its like it has no fuel. now i am looking a a carb and a FI setup. or the pump? ill DMM it tomoro when i get pics. please someone try and help me here, i need it bad. the car is in great shape otherwise. thanks for looking.
Old 04-26-2008, 07:14 AM
taillight taillight is offline
Re: Biggest hack job
Check for fuel pressure to the carb.
Old 04-27-2008, 07:28 PM
so i checked to voltage to the fuel pump. and there was 2volts. is that right? shound't it be 12? also i cant hear the fuel pump engage when the ignition is turned on. Should i replace the fuel sending unit?
ill get pics soon, sorry bout that.
Old 04-27-2008, 07:48 PM
You should have 12 volts to the pump with the engine running or cranking.
Old 04-27-2008, 08:46 PM
so what need to be replaced then?
Old 04-27-2008, 08:53 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
I gotta see these pics.
Old 04-28-2008, 06:56 AM
The fuel pump for the carb should have about 5 pounds of fuel pressure. For the turbo it is about 60 pounds. If it still has the turbo pump, if you do get it working, the carb will flood.
Old 04-28-2008, 07:54 AM
ok where is the turbo pump located? i know that the car was running great so i dont think it has the turbo pump on it....
Old 04-28-2008, 07:55 AM
and what about the fuel injection system on it?
Old 04-28-2008, 08:40 AM
The pump is in the tank.
Old 04-28-2008, 06:55 PM
ill have pics up in a few hours. i am going there right now....
Old 05-01-2008, 01:35 PM
Few hours turned into a few dayz, lol. sorry guys im really busy.....
Here is just a pic of the rear of the car. it is almost 100% rust free
As i found in an auto wreckers yard. the whole carb, fuel injection thing is on these cars as stock. i do not understand....
and these two shots are between the fire wall and the engine. where the turbo should be.....
I poured gas into the carb and canked it and she started right up and ran untill the carb dried out. I DMMed the fuel pump came up with 3 volts at the pump. found the wiring in the cab and got 12 volts. i pulled the tank and bought a brand new fuel pump. The tank was taken and steamed out so it is clean as a whistle. Hoping this will all work out????
Old 05-01-2008, 01:37 PM
lol, and the House plumbing that is on there for whatever reason is changed out with that flex tube stuff. lol, i chuckled pretty good when i seen it.
Old 05-01-2008, 10:47 PM
madmanmapper's Avatar
madmanmapper madmanmapper is offline
If you really want to save this car, why don't you convert it back to its original fuel injection (perhaps turbo as well)??? Just go junk yard hunting every now and then. I've seen these turbos in the junk yards from time to time. Hell, I even spotted a Maserati TC in the junkyard once... poor thing.
