Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 04-25-2008, 02:45 PM
Bandit58301 Bandit58301 is offline
Question 93 Lincoln Will Not Start
93 Lincoln Cont. car wont start. Main relay box on the radiator support just buzz's. Any ideas on what to check, I already checked all the fuses.
Old 04-28-2008, 06:50 PM
danielsatur danielsatur is offline
Re: 93 Lincoln Will Not Start
What do you mean!, that it won't start?
1) Does the electrical starter turn the motor over?
2) When you turn on Lights will the horn honk?
If NO, have your battery CHARGED + LOAD Tested.
If Yes ,go to step 3.
3) Put some starting fluid in the INTAKE!
Does she fire now?
If yes,you got a fuel problem.
Suspect:
1) Fuel filter
2) Fuel pump Relay
3) Fuel pump fuse
4) Electric fuel pump
5) Fuel rail pressure switch
Note: We need some good Feedback
Hey! - You guys should of started a Thread ''Lincolns don't start'' F.O.R.D.
MCGIVER
