Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 04-25-2008, 01:29 PM
jkingiii jkingiii is offline
Overdrive light is flashing....96 town car
I have 96 town car and the O/D light flashes on and off. I have the switch turned on so it's not that problem. Has anyone ever had that problem. I've noticed my gas milage is starting to get worse.
Old 04-25-2008, 02:10 PM
Towncar's Avatar
Towncar Towncar is offline
Re: Overdrive light is flashing....96 town car
I'm looking through the FSM for more answers, sometimes it can be overwhelming...
Here's a bit of warning info from the Owners Manual:
-Steven
1996 Town Car, Cartier
Old 04-25-2008, 09:38 PM
danielsatur danielsatur is offline
There's something wrong with the overdrive,there's probably
a DTC code stored in memory.
When the Torgue coverter slips,the system will generate a DTC.
Old 04-26-2008, 01:54 AM
myvwisfast's Avatar
myvwisfast myvwisfast is offline
I read on another forum somewhere that the flashing light is an indicator of a malfunctioning Vehicle Speed Sensor (VSS). It's located on the tailshaft of the trans and it's real easy to swap out & relatively cheap & readily available @ any auto parts store. You don't even need to jack the car up to do it. Good luck.
Old 04-26-2008, 07:38 AM
I had a 1995 Windstar minivan,which I replaced two VSS for the same type of problem.
It's worth the time + money doing it yourself, unless you got $1500-$3000 to give to Transmission shop.
How did you get your pix to move?
MCGIVER
Old 04-26-2008, 01:07 PM
Towncar's Avatar
  • Press elbows inward toward the stomach
  • Lift heels from the floor repeatedly until boobs are bouncing
  • Repeat as required
-Steven
Old 12-20-2008, 01:17 PM
wisesam wisesam is offline
[quote=jkingiii]I have 96 town car and the O/D light flashes on and off. I have the switch turned on so it's not that problem. Has anyone ever had that problem. I've noticed my gas milage is starting to get worse. [I have the same problem on a 97 town car the transmission shop already replaced the computer to the tune of 600 bucks and the problem started again it is back in shop with no answere....please help/quote]
Old 12-20-2008, 01:30 PM
MCGIVER
I have a 97 town car with the o/d flashing lite, took it to the transmission shop and they put a new computer on it ,drove for about a week and problem started all over again but worse, back to the shop, Please help
