Go Back   Automotive Forums Car Chat > Chevrolet > Blazer > Interior | Exterior | Appearance
Interior | Exterior | Appearance The place for all interior, exterior and general non-performance modifications.
Old 04-25-2008, 01:40 AM
dksram
Guest
Posts: n/a
Manual window Panel Removal
Well I did my best to show how to remove the panel.I used the rag method to pull the window handle clip.That tool everyone talks about is crap.I have one and never had any luck with it.
There are (9) clips along the edge of the door panel and one on the upper part of the panel that is the same color as the panel.
There are (3) screws that have to be removed. One in the door handle bezel and (2) underneath the door handle.Which you will notice I discovered after removing the panel. The screws are set at an angle and require a 7mm socket.If you need to remove the mirror it is easy. (3) 10mm nuts hold it in place.
