Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 04-24-2008, 03:26 PM
roufus sided towhe roufus sided towhe is offline
oil filter remomal 2000 sunfire 2.2L
[IMG]file:///E:/DOCUME%7E1/user/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG][IMG]file:///E:/DOCUME%7E1/user/LOCALS%7E1/Temp/moz-screenshot-1.jpg[/IMG]I looked in the Haynes manual and found the filter in the back pasenger side of the engine. Is there a special oil filter wrench or hose/housing removal to get the filter out - I was able to drain the oil from the pan and wound up later takinf it to a shop th change the filter. Thanks in advance for the help.
Old 05-08-2008, 08:14 PM
pbellone's Avatar
pbellone pbellone is offline
Send a message via AIM to pbellone
Wink Re: oil filter remomal 2000 sunfire 2.2L
Just bought a 97 and changed oil & filter. The filter wasn't on tight so my hand did the trick. But after screwing on the filter I did give it a small filter wrench turn. Just make sure you get the one for the small filters not the PF35 size. Just go up the right side on the filter and find the right spot.
Old 05-17-2008, 08:19 PM
cymdeathlord cymdeathlord is offline
well the filter should be above the cat if it is a automatic it will be harder to get at might have to go in through the wheelwell i just used a normal filter band wrench to take them off.
