Go Back   Automotive Forums Car Chat > Chevrolet > Lumina APV
Old 04-24-2008, 11:51 AM
superman28 superman28 is offline
1994 Chevy Lumina APV, Cranks but no spark
I have a 1994 Chevy lumina APV, It will crank but it has no spark. I changed the distributor cap and rotor, changed the ignition module, fuel pump is working fine. Does anyone have any ideas of what it could be. I am thinking it might be the ignition coil. I am lost. HELP!
Old 04-24-2008, 03:33 PM
LMP's Avatar
LMP LMP is offline
Re: 1994 Chevy Lumina APV, Cranks but no spark
Well...ignition coil is a convenient culprit...but it is rarely a problem; if you can test with another, do it so you can put that behind of solve the problem..
Of course, check for continuity of 12V feed .
diagram here in case you do not have that;
www.avigex.ca/xport/ignition31.jpg
www.avigex.ca/xport/ignitionkey31.jpg
www.avigex.ca/xport/ignitionpickup31.jpg
Is your Cehck Engine Light ON?
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 04-24-2008, 04:39 PM
No The Check Engine Light Never Came On At All. And It Still Won't Start, I Tested The Ignition Coil And It Tested Fine. So What Gives Then?
Old 04-25-2008, 12:31 PM
I figured it out. It is the timing chain. Hard job to do yourself, I recommend bring it to a garage to let then do it. It is pretty expensive as well, Mine cost me almost $1000.00. So if you have patience and some skills you colud do it yourself. Thanks for the help everyone.
Old 04-26-2008, 10:34 AM
LMP's Avatar
LMP LMP is offline
...mm...how did you figure that out? If you pull the distributor cover and it does not rotate when you start, it can be a broken camshaft....this has happened quite a few times in this forum, mostly with the 3.4..but part # is the same....http://www.automotiveforums.com/vbul...d.php?t=900759
If you have any doubts, remove front valve cover and check how many valves work...in all reported cases, the cam broke about in the middle.
