Old 04-24-2008, 02:17 AM
derka-derka derka-derka is offline
Zero Paints
After base coating with zeropaints, is it neccesary to sand out orange peels b4 clear coating? and how many clear coats are recommended to achieve a nice finish....im having no luck with using zero paints + TS-13 clear coat...clear coat dries into a dull finish...
Old 04-24-2008, 03:05 AM
gionc's Avatar
gionc gionc is offline
Authorized Vendor
Re: Zero Paints
There is something wrong: I used TS13 over Rosso Corsa and Grigio Alloy without troubles, with a great shine.
Also I never got orange peel from Zero bases: I usually thin a bit: also becouse the plastic jar allow evaporation (A LOT!!!!!! I'm almost an alcholist without drink nothing, just breathing vapours LOL). You'll sand down since they're hard enough, in the other hand you'll be able to do a zero base paintjob without orange peel: low pressure (10-15 PSI), thinned color... no much more, they're great.
gio
Old 04-24-2008, 04:56 AM
sjelic's Avatar
sjelic sjelic is offline
Re: Zero Paints
There is no way you can get orange peal from Zero paints, orange peal is from primer or whatever is under it. The thing is, not to use it to much, as Gio said, nice and easy, low pressure, thin coats, just build them slowly, paint must cover but it must be extra thin, don't use heavy coats, just wave over the model like Rembrandt
Sasa Jelic
SCALEMAKERS
Old 04-24-2008, 05:16 AM
Re: Zero Paints
hmm...maybe ill order another bottle and try again...i have a tamiya spray work airbrush and it dsnt allow control to pressure...but i think its within range....
Old 04-24-2008, 07:52 AM
pawlie's Avatar
pawlie pawlie is offline
Re: Zero Paints
I agree with sjelic, never had any orange peel w/ zero paints.
Fantastic stuff in my opinion
Old 04-24-2008, 07:58 AM
proosen's Avatar
proosen proosen is offline
Re: Zero Paints
No orange peel here either.
Just a good and smooth coat of primer for the base coat to attach to and you should be fine.
This is a 288 GTO hood with Zero primer and Corsa rosso with no sanding on the rosso. Just a good layer of clear on top of it and it was fine.
I find Zero-paints very easy to work with, sprays easily and covers good.
Niclas
Old 04-24-2008, 08:00 AM
Re: Zero Paints
since im trying it for the first time, i havent got used to it yet....approximatly how much zero paint will be adequete to cove the whole car body....cos ive pretty much finished the bottle by now and i think ive over used it....im starting to sand everything flat again and go with the EXTRA light coats...
prbly like sprinkle the coats on...
Old 04-24-2008, 08:02 AM
gionc's Avatar
Authorized Vendor
Re: Zero Paints
The pressure must be controlled by the compressor meter that ususally is unique body with the moisture trap or mounted aside: than you'll use ever also a single action AB. I thought a moisture trap is necessary, I installed a second little one just fitted to the airbrush and I feel better spraying 2K clears.
gio
Old 04-24-2008, 08:05 AM
Re: Zero Paints
Niclas
thats some nice painting there...is the polished or just straight after clear coat??
and may i get some tips on the clear coat...how many coats and how heavy are the coats of clear did u have??
Old 04-24-2008, 08:55 AM
cyberkid's Avatar
cyberkid cyberkid is offline
Re: Zero Paints
I do about 10 coats in total all very thin, sort of like mist to medium.
2 or 3 mist and then start with the mist medium coats.
I've used 2k, Tamiya's clear and Gunze's super clear all without problems. Only 2 coats with the 2k though, 1 mist tack coat and 1 wet coat just like in Hiroboy's tutorial.
As for the Zero paint, a 2ounce (60cc) bottle lasts me 2-5 cars depending on what color it is and how much space I need to cover.
HTH
Steve
Please read the following linked articals before posting a question.
Once you have and still have questions, try to post your questions clearly.
This will make a lot of people's blood pressure drop back to normal, including mine.
NEW TO THE AF MODELLING FORUM? PLEASE READ THIS FIRST
AF Car Modeling Tutorial, How-To and Product Review Depository
AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0
And finally,I wish you all happy modeling
