Stealth will not start
I have a 91 Dodge Steatlh that will not start. Before I took it to the shop it would crank but not start. Now it will not crank at all. I had the car towed back to my property. The fusible link had to be replaced, but it has been replaced. Also, at first the radio would not get any volts and now it does. I can hear the MFI relay click whenever I turn the ignition, but it nothing else makes a sound. I do not hear the starter engage or disengage at all. Any ideas? Is there any automatic shutoff items that would cause this? Any ideas at all?
Re: Stealth will not start
Dead battery
As a precaution check all your underhood sensors like TPS, crank angle, PTU, and check your coils, wires, alternator, spark plugs and battery.
Never bring show to a go fight.
And a TT conversion brewing.. |
I would start with the battery. Then I would work on getting the starter to crank. Check the starter relay first (which is different from the MFI relay), then check the starter itself if the relay is good. Once you get it cranking, then concentrate on getting the engine started. Next check to see that your car is getting fuel and getting spark, then let us know of your findings.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition 1994 Mitsubishi 3000GT SL-TT Automatic - Black 3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods 1994 Mitsubishi 3000GT VR-4 - Black Intake & Boost Controller so far 2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods |
