Old 04-23-2008, 08:23 PM
jetdriver jetdriver is offline
Fuel pump
Replaced fuel pump 4 month ago with factory pump. Know it only works half of the time? What is the problem?
Old 04-24-2008, 08:15 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Fuel pump
Year make and model and engine would help.
Explain the 1/2 time working.
Is it losing pressure or just pump or engine quits running?
MT
Old 04-25-2008, 06:40 PM
j cAT j cAT is offline
Re: Fuel pump
on a 96 vehicle i would have replaced the fuel pump relay when the fuel pump was replaced...also check grounds for fuel pump....on the 1999 on up silverado the ground point is on frame rail next to fuel tank... these wires/stud connections get rusted ....
Old 05-06-2008, 06:20 PM
Chevy-SS's Avatar
Chevy-SS Chevy-SS is offline
Re: Fuel pump
I had bad problems with aftermarket fuel pumps, then finally had the shop install OEM pump. Now all is well.
1968 427 Camaro SS
1998 Silverado K1500
2004 Corvette Coupe
2011 Chevy Avalanche
______________________
Old 05-08-2008, 12:19 AM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
Re: Fuel pump
chekc ignition switch or replace it
check oil pressure switch or replace it
and the FP relay of course
all of these are in the FP circuit
check grounds also, and vcheck wiring plugs in the FP wiring from the cab back to inside the FP
some connectors for the FP are known for failing
is a common issue depending on the year make model
commonly new FP wiring pigtal connectors are sold over the counter due to this
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
