Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-23-2008, 07:19 PM
richard.fisher101 richard.fisher101 is offline
can't get it started again!!
i have a 91 camarro RS with a 305 4.0 and 700R4 trans but for some reason it died the other day and now it refuses to start again. S/S the starter is turning but i'm not getting any juice from the coil to the distrubitor cap. no lights are on inside and i'm clueless. i've tried replacing the coil and the coil wire to the distributor but still no luck if any one has any idea's please let me know.
-thanx
Old 04-29-2008, 09:08 AM
GreyGoose006 GreyGoose006 is offline
Re: can't get it started again!!
how do you know that you arent getting juice to the distributor cap?
Old 05-13-2008, 11:24 AM
chevyrulespops's Avatar
chevyrulespops chevyrulespops is offline
how many miles on the car? what type of fuel system do you have TBI TPI? what was the first no start problem?
Old 05-13-2008, 11:28 AM
you should be getting close to 12 volts at the pink wire going into the ignition coil where u turn your key to the start position...check to see if you have those 12 volts...you have an HEI system?
Old 05-13-2008, 12:27 PM
mikeemon's Avatar
mikeemon mikeemon is offline
What do you mean, "no lights are on inside"?
Old 05-27-2008, 07:52 PM
LT1LS1inTexas LT1LS1inTexas is offline
is your security light on?
could be the VATS.... if ur security light is on
