Old 04-23-2008, 12:35 PM
lesabrefan lesabrefan is offline
1996 Lumina turning signal handle
Good day!
When handle is pressed to indicate the right turn, it does not return to the "pre-pressed" position after the vehicle had made the turn. It's stuck in the lower position and the blinker is still blinking. Is there anything I can do myself in the steering column to fix that/
Thanks in advance.
Old 06-25-2009, 10:13 PM
[email protected] haueni@yahoo.ca is offline
Re: 1996 Lumina turning signal handle
Same thing on my 96 Lumina, except the left indicator. I was told by dealership that the entire assembly has to be replaced. Have to take apart the steering wheel assembly...cost $400.
Old 06-25-2009, 11:27 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Welcome to the forums!
I know this is an old thread, but if people are going to dig it up, I would like to provide what I think is an accurate and proper answer.
Originally Posted by lesabrefan View Post
Good day!
Thanks in advance.
This is an easy and simple repair.
These columns use tiny springs as part of the turn signal mechanisms. When the spring breaks, the signal lever no longer cancels itself.
The springs cost just a couple of dollars. You have to remove the steering wheel to access them. Once the wheel is off, the replacement takes just a few seconds.
Personally, I think working around a steering wheel airbag is not for a beginner. It can be very dangerous so may be wise to let a pro swap them over.
But its a quick and easy repair. You should replace bot the left AND right turn return spring. If one broke, the other may not be far behind.
