Go Back   Automotive Forums Car Chat > Ford > Escape | Maverick | Escape Hybrid
Old 04-23-2008, 09:44 AM
bass440 bass440 is offline
Check Fuel Cap Light On
I recently bought an '03 Escape with about 82K miles on it. This morning the 'Check Fuel Cap' light came on while driving. It's been several days since I'd fueled up, and was surprised when this came on now.
After checking the cap, all appears to be well. I believe it was already tight, but I snugged it up just to make sure. Cap shows no kind of damage of any kind.
Is this a symptom of other problems, or can the cap lose it's function and cause the light to come on?
Should the light turn itself off when the problem goes away, or does it need to be reset manually?
Thanks for the help.
Old 04-24-2008, 08:28 AM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Re: Check Fuel Cap Light On
Cap can be defective. I would replace it. Not expensive.
Old 04-24-2008, 04:20 PM
Okay, I replaced the cap, and there was no change.
Basically, doesn't the light on the dash indicate one of two things?
1) there's an air leak somewhere in the pressurized fuel system (which seems unlikely based on no performance changes)
2) the sensor (or it's subsystem) that turns the light on the dash is defective
Any ideas or opinions are welcomed. Thanks.
Old 04-24-2008, 06:11 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
There might be a leak in the evap system somewhere. Could be the fuel fill or anything.
Old 04-25-2008, 08:33 AM
AlohaBra's Avatar
Did you clear the CEL after the new cap? (Disconnect the battery or use a codel checker to clear.)
