Old 04-23-2008, 06:20 AM
lowedawg20 lowedawg20 is offline
93' 5.7 seirra stalls when accelerating
I have a 93' seirra with a 5.7l v8. When I start to accelarate it cuts out. Once the rpms get up it runs find. I have went through it. Fuel psi good. No codes. It has a Holley throttle body on it. Do I have to adjust anything for the Holley?
Old 04-25-2008, 03:53 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 93' 5.7 seirra stalls when accelerating
Did it act up after installing the Holley TB? If so, I would contact them. The TPS may be different than stock.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 04-25-2008, 07:32 PM
2000CAYukon 2000CAYukon is offline
If the TPS is correct, check to see if the MAP is connected to right port or acceleration will not be correct (assuming everything else is operating properly). The MAP needs manifold vacuum to work properly.
//2000CAYukon
Old 04-26-2008, 07:33 AM
The holley throttle body was already on it when I bought the truck. Just about all the sensors are new. I just change out the egr valve and it helped a little. It still stalls when I floor it though.
Old 04-28-2008, 04:10 PM
J-Ri's Avatar
New doesn't always mean good. I've had several new parts that were bad.
Also check the fuel pressure, if the pump volume is low, sometimes the increased injector pulse width can drop the pressure enough to make the engine stall.
Old 04-29-2008, 07:04 AM
Just changed out the fuel pump because of low psi. Have had the truck in the shop for a while. Mech said it might be the ECM. ANy way to check?
Old 04-30-2008, 03:39 PM
J-Ri's Avatar
You would have to figure out whether it loses fuel pressure, injector command, or spark when it dies. Then check the PCM output that controls whichever it loses. Then check the input the ECM uses to decide whether to command (part X) on. This is a situation where I might actually suggest swaping it for a salvaged one. It would be a lot easier than diagnosing it properly, and probably not too expensive.
Is the fuel pressure where it should be now? Did you chack the MAP sensor?
Old 04-30-2008, 04:52 PM
I keep getting a Code 35 Idle Air Control. I changed out the IAC valve but still not right. How do I check the valve and harness for proper function?
