Go Back   Automotive Forums Car Chat > Honda > Integra
Old 03-03-2003, 07:15 PM
TheNotoriousMogg's Avatar
TheNotoriousMogg TheNotoriousMogg is offline
AF's #1 Bad Guy
Send a message via AIM to TheNotoriousMogg Send a message via Yahoo to TheNotoriousMogg
Manual Tranny Swap
Ok, I just aquired 1,200 how much would it be to convert my auto tegra to manual and what do i need
Darrell
thegrumpysergeant.net
Old 03-03-2003, 10:10 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
You will need The tranny, clutch fluid reservoir , the line that run to the tranny from the clutch reservoir, clutch master cylinder, clutch slave cylinder if not connected to the donated tranny, pedal assembly, new ecu or you can take the ecu appart and remove the resistor from location RP17 and solder it into location RP18, not a must but a new gauge cluster, tranny mounts, not sure about the axles I think they are the same length some one correct me if I am wrong. That is all I can think of at the moment. It would be best to just get all this stuff off of the car you get the tranny from. Hope this helped
