Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 04-22-2008, 11:52 AM
KRUKR29 KRUKR29 is offline
03 XLT rear entertainment DVD remote
I recently purchased this vehicle w/factory DVD system bought remote from e-bay. No instructions for programming. Can anyone help?
Old 04-22-2008, 12:38 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 03 XLT rear entertainment DVD remote
Welcome to the forum!
Instructions for programming the remote? You shouldn't need to, it should just work with the factory DVD player.
Are the batteries in the remote good? Any sign that batteries have leaked in the remote? If the batteries are good and the contacts are clean, this remote may have broken solder joints on the IR transmitter. It seems to be pretty common for the solder joints to fail, especially if the remote has been dropped or tossed around a few times. It's a simple fix if you are handy with a soldering iron.
-Rod
Old 04-23-2008, 01:36 PM
Hey Rod Thank You. I Will Take A Look Today After Work. Also If You Would Happen To Know. My Computer Module For The Keypad On The Door Isnt In The Rear Storage Area. Any Idea Where It May Be?
Old 04-23-2008, 10:47 PM
shorod's Avatar
SHO No Mo
I don't know if it moved for the 2003 model year from 2002 (I doubt it). In the 2002 model year the Central Security Module that the keypad interfaces with is located behind the rear seats on the Right Hand side. I'm not sure if you can remove a little access door somewhere to get to it or if you'd have to remove the right hand rear interior trim panel.
-Rod
