Go Back   Automotive Forums Car Chat > Lincoln > Mark VIII
Old 04-22-2008, 10:23 AM
Goddard007 Goddard007 is offline
Misfire on 3
I'm having a misfire on 3 and don't know why. I've changed the plugs the connectors and checked the coils those are all good. I checked the injectors by disconnecting each and seeing if it had a affect on the misfire it actually made it worse as it should. I've heard people talk about spark knock and decarbing not sure if this is the step I should take, but any help would be nice.
Side note another problem I had was with the MAF sensor or probably not with the sensor. I connect the sensor I hear a sort of pumping sound I disconnect the sensor I hear it no more. What could that be as well?
Any help is much appreciated been workin on this for awhile and its driving me crazy!
Old 04-23-2008, 02:40 AM
el lobo's Avatar
el lobo el lobo is offline
Re: Misfire on 3
You may get a better response if you indicate the year of your car.
My misfires have always been a coil on plug boot.
1998 Mark VIII Collectors Addition
el lobo
1998 Mark VIII
Collectors Addition #106
Old 04-24-2008, 01:17 AM
Re: Misfire on 3
its a 97...I changed the boots and connectors and plugs fuel filter and still no luck fixing the issue.
Old 04-24-2008, 02:55 PM
Towncar's Avatar
Towncar Towncar is offline
Re: Misfire on 3
Not sure if the 97 coils can be swapped, but it's standard diagnosis practice to swap /em around to see it the fault follows the swap.
-Steven
1996 Town Car, Cartier
Old 04-24-2008, 05:09 PM
Re: Misfire on 3
yeah I did that. No luck.
Old 04-25-2008, 11:19 AM
Towncar's Avatar
Re: Misfire on 3
There was a guy at lincolnsonline with the same issue, his was at a specific RPM.. replaced everything.. no luck. Frustrated, he sold the car.
He had lots of help, many sound tests and recommendations.
-Steven
Old 04-26-2008, 10:02 PM
Re: Misfire on 3
I'm thinkin its a compression problem...now I just need a good dvd or manual because I've never fixed something like this before....what could it be?
Old 04-26-2008, 10:43 PM
Towncar's Avatar
Re: Misfire on 3
Originally Posted by Goddard007
. ...now I just need a good dvd or manual... .
I have your FSM on my webpage.. follow my username..
-Steven
Old 04-26-2008, 11:00 PM
Re: Misfire on 3
dude thats bad arse thanks bro....if you ever need some mirror for some of that stuff I'll put one up.
Old 04-27-2008, 12:34 PM
Towncar's Avatar
Re: Misfire on 3
The traffic's been enormous lately.. I have all the originals, even some DVD's I can't host, but using megaupload doesn't cost me anything.. happy to help out.
Most of you folks were willing to help out when I needed it, just returning the favor.
-Steven
Old 07-03-2008, 08:08 PM
dieseltechcv's Avatar
dieseltechcv dieseltechcv is offline
Re: Misfire on 3
I have the same problem with my car, i actually see the code P0351 and P0353 i have replaced all, sensors (Cam and Crank) and wiring, uincluding coils, plugs and wires, i know computer works becuase i get the signal from the ground wires to colapse the primary circuits in the coils but still misses. I don't have COP but i'm i'm planing to go back to EDIS instead of DIS. I know this doesn't solve your problem, but its interesting to know that i'm not the only one that can't find the missing plugs. Its interesting becuase i got my car to work once, i don't know what happened it just work fine, and 20 minutes later it ran like crap, so before going for COP or EDIS i'll try swaping another ECU for the Mark VIII just to test it.
