Go Back   Automotive Forums Car Chat > Oldsmobile > Achieva
Old 04-21-2008, 11:12 PM
slobo7x slobo7x is offline
95 2.3quad achieva, valve cover problems
I have a nice oil leak at the valve cover location and I attempted to remove the valve cover closer to the front of the engine..Since i had the fuel rail out for cleaning it was easily accecable.
I removed all the bolts on top(10 i think) and the power steering pump or whatever that thing is, attempted to take the valve cover off but the cam inside went up with it? I've never seen an engine setup like this, and i am truely confused. I have that achieva service manual from autozone but it's no help. I could not get the valve cover out, so i just installed the bolts back in..
Also where exactly is the fuel pressure service port on the fuel rail, i did not see one on this 95 achieva 2.3quad engine.
Please help me out!
Thank you
Old 04-27-2008, 12:47 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: 95 2.3quad achieva, valve cover problems
Welcome to AF.
YEah sometimes the cam will pull out when poping off the valve cover.
Did you replace the gasket ?
....thats most likly whats causing your leak.
And you did torq them bolts to spec I hope ?!
Your Quad doesnt have a fuel port, you have to install a hose with a gauge, you can rent/buy at most part stores.
Sorry for the delayed reply , and I hope that helps!
1999 Grand Am SS 3.4 OHV
Old 04-27-2008, 08:22 PM
Thank you for the reply.
It was just a lot of work, and it needed a new head which wasn't feasable..
We decided to donate the car instead.
