Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 04-21-2008, 06:06 PM
miguel2112 miguel2112 is offline
99 aurora a/c not cooling
Now its time to use the a/c and for some reason it's not cooling well. I don' t have manifold gauges but I do have a simple refill line with a gauge on it. Low side pressure is 42 psi, compressor runs continously. Also it seems that the small vent on the passenger side just to the right of the center console is blowing cold air while all the rest aren't but this I think? Any ideas, thanks
Old 04-21-2008, 06:16 PM
kameraguy61 kameraguy61 is offline
Re: 99 aurora a/c not cooling
Sounds like you are having the same problem I am on my 1999 Aurora, still waitng for a response. I believe it is a vacum module since I had it repaired at the dealer when we bought the car a few years ago, but the problem is back. did not take them long to fix, but as you know the dealer charges way to much, but most AC shops do not seem to be vary familure with the Auroras.
Old 04-21-2008, 07:13 PM
maxwedge maxwedge is offline
A990 racer
42 is too high your symptoms sound like slighly low on freon.( re: the OP)
Old 04-21-2008, 08:42 PM
but if the pressure is too high, won't adding more freon make it even higher?
