Old 04-21-2008, 08:45 AM
mrmagoo32 mrmagoo32 is offline
95 Chevy Blazer 4.3 No Start
HI MY NAME IS PERRY AND MY BLAZER HAS DIED ON ME AGAIN !!!
I REPLACED THE SPIDER ASSY. APP 6 MONTHS AGO , ALONG WITH THE FUEL PUMP. AFTERMARKET PUMP COULD NOT SUPPLY ENOUGH PRESSURE SO IT RECENTLY HAS GOTTEN A NEW FACTORY PUMP - NOW AFTER A NEW COIL,MODILE,EGR VALVE,FUEL FILTER IT WONT START UNLESS YOU USE EITHER BUT IT ONLY STARTS THEN FALLS ON ITS FACE AND THE CODE P1351 IS IN ITS MEMORY
Old 04-21-2008, 10:06 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 95 Chevy Blazer 4.3 No Start
Welcome to AF.
The code indicates Ign coil module voltage problems.
Clear code and unplug injectors and crank engine and see if code returns.
If so inspect wiring and plugins on ign module and coil.
Next step is a voltage test of the cirucuit.
Could be a bad ign coil module or any thing on wiring or even pcm plug in.
And go easy on that starter fluid.
Safer to use carb cleaner for a start aid.
If it starts on carb cleaner it is more of a fuel deliver problem than ign.
I would ckeck the fuel pressure first thing.
MT
MT
MT
Old 04-21-2008, 10:41 AM
i have a friend helping me check the wiring and we removed the upper half of the intake manifold and we are not getting an injector pulse
Old 04-21-2008, 11:50 AM
MT-2500's Avatar
AF - Advisor
Is it a PCM or VCM engine.
Is it a code Z or W engine.
PCM computer engine the computer is behind glove box or inside cab.
VCM the computer is under water tank on right side fender well.
Do you have good spark to all plugs and good fuel pressure?
where is it losing injector pulse or where and how are you checking for injector pulse?
At injector or wiring going into intake or at computer?
MT
Old 04-21-2008, 11:56 AM
MT-2500's Avatar
AF - Advisor
Have you checked all fuses for 12 volt power on both side?
Check all emc/batt/ign/injector fuses real close
MT
Old 04-21-2008, 11:57 AM
i believe it is a pcm ( computer mounted on the fender well ) and the 8th digit is a W THIS VEHICLE IS DRIVING ME CRAZY . 4.3 L. CENTRAL MULTI-PORT
Old 04-21-2008, 12:09 PM
Tou Wouldnt Happen To Live Near Waverly Va Would You???
Old 04-21-2008, 12:11 PM
I Have Fuel Pressure And Spark , But No Injector Pulse
Old 04-21-2008, 12:25 PM
MT-2500's Avatar
AF - Advisor
Where are you checking and how are you checking for injector pulse?
Fender mounted computer is a VCM computer.
Check for injector pulse at connector 2 pin 3 out of VCM.
Have you cleared codes and checked fo any codes coming back?
DO YOU HAVE A SCANNER TO READ OUT rpm SIGNAL OR INJECTOR PULSE?
MT
Old 04-21-2008, 03:10 PM
checked injector pulse at injector and connector with noid light now for the stupid question which one is connector 2 and pin 3.
have cleared codes several times and code p1351 keeps comming back
Old 04-21-2008, 03:55 PM
which connector is #2 black or grey ????
Old 04-21-2008, 04:12 PM
blazer_momma blazer_momma is offline
This is going to sound a bit odd, but check in or near your glove box for a fuel injector relay. I have had the same problem for 4 weeks. Mines a 94, but your's should be in the glove box, under it, or behind. Sorry not certain on where.
Old 04-21-2008, 06:54 PM
MT-2500's Avatar
AF - Advisor
Does it come back with injector unpluged?
MT
Old 04-21-2008, 07:44 PM
MT-2500's Avatar
AF - Advisor
Should be stamped on the connector.
Connector does not have any wires on pin 1 or 2.
Pin 3 injector wire is a dark/blue wire.
MT
Old 04-22-2008, 03:23 PM
still at a loss the vcu has 4 connectors black grey red blue none are stamped connector 1 etc...
