Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 04-21-2008, 01:13 AM
kameraguy61 kameraguy61 is offline
Phantom cooling leak
Our 1999 Aurora looses colent, not a lot, not even enough to see leakage on the ground. I have replaced all hoses and flushed the Radiator. There is no leakage I can find on the inside like it might be a heater core. I am stumped. I have to top off resavore about once a week.
Old 04-21-2008, 05:34 PM
93pb 93pb is offline
Re: Phantom cooling leak
Check your oil is it milky white? Or smell your exhaust with engine running does it smell like coolant?
Generally when you consume coolant and no obvious leaks then it is a head gasket issue and the coolant is getting burnt up in combustion or contaminating the engine oil..
Good luck:
Marc
Old 04-21-2008, 06:10 PM
Thanks, I have checked the Oil and it seems fine, I keep the oil changed regular, the only Coolent smell comes from the engine compartment.
Old 04-22-2008, 06:11 PM
you could pull the plugs and see what they look like, that may help the diagnosis.
Marc
Old 05-01-2008, 09:51 PM
nicks84 nicks84 is offline
Do you have the pellets in there ? That is supposed to stop small leaks. It could be the bearings or seal in the inside of the water pump. It gets pretty hot, so if its a slow leak, it might just burn the coolant before it has time to drip ? Have it leak checked, that should be so expensive. That might tell you something.
Old 05-05-2008, 01:53 AM
pizza442 pizza442 is offline
Send a message via AIM to pizza442 Send a message via Yahoo to pizza442
Take a real close look at the plastic radiator tanks (on the sides of the radiator, not the overflow tank) for hairline cracks. Especially around the tranny cooling lines (and engine oil cooler lines on the passenger side tank, if so equipped). I smelled the coolant, too, with no dripping. Thought it was the water pump again, 'till I got a flashlight and stuck my head in there to see the evidence of seepage from a thin crack. Wouldn't drip when sitting. I think it expanded while the system was being pumped up at speed and the leakage occurred while moving.
It is my belief that a cracked rad. tank is the most common start which leads to the overheating that commonly causes the Northstar headgasket issue. Got my mom in her 1999 80k mile Caddy Concours Deville; rad. cracked, low coolant, overheat, dealer says one side headgasket bad. Check those radiator side tanks closely.
Old 05-19-2008, 06:59 AM
55624096 55624096 is offline
Check the 4 gaskets between the water pump housing and the block. These deteriorate and cause slight leak. If this is the problem you will see small coolant droppings under car after being parked over night. Starts real small and get bigger and bigger
Old 11-04-2008, 07:43 AM
ERNESTINE ERNESTINE is offline
My 97 Aurora has the same problem. I might go a month or so and have no problem then it will leak and I have to fill it frequently. I'm getting really frustrated over this. Did you find your problem? Would love to know if you did.
Old 11-04-2008, 07:51 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Sorry but please start a new post following the guidelines below. This thread has been closed. Thank you for your cooperation.
Old Thread Guidelines
Timeslip 08/12/06
AF Community Guidelines
Closed Thread
