Old 04-21-2008, 12:23 AM
chellesman chellesman is offline
92 ramcharger no fire-bumpy road
I have a 92/(91) dodge ramcharger with a 360.. I live on a very bumpy road. for a couple of days , I would stall out while going down the road- then reswitch ignition.. good to go.... after a couple of day- died. wouldnt restart, pulled home.checked coil fire-plug fire- then just started....good for 3 days.. then same thing, after a big bump. checked fire- none from coil...vehicle history= just replced computer for alternator not charging 2 weeks ago...Maybe a loose wire at the comp.? I dont know...just dont think coil with the intermittant prob. please advise
Old 04-21-2008, 07:29 PM
maxwedge maxwedge is offline
A990 racer
Re: 92 ramcharger no fire-bumpy road
Welcome to AF, I had a similar failure on a 92 Van, was the coil. Cheap enough.
Old 04-22-2008, 03:36 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Just check the coil with a test light the next time it dies. It should have power on one terminal and a flashing ground on the other. If it has both, replace the coil. Although, I'm the type of person to replace the coil and see if it ever dies again
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
