| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
i tried to search for this problem, but i have no idea what its called so sorry if its a repost... in my 95 talon, about 50% of the time my car will not let me accelerate past 3000 rpms with the clutch engaged or disengaged... the needle just bounces around 3000... sometimes if i shut the car off and back on it wont do it, then other times it does do it... im still a beginner and trying to learn but id really like some input before possibly getting raped by another mechanic
1995 Eagle Talon Esi "I shall call her Eileen"
Re: random stuttering at 3000 rpms
Cel?
'98 Contuor SE, 2.5 V6 Auto Silver '08 Altima 2.5S, Auto Super Black |
Check Engine Light
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
oh lol my bad... no, the "cel" doesnt come on..
So even in neutral the car wont rev past 3k sometimes?
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
thats what it sounds like. Which means it must be some sort of ecu cut happening. (LIke a stutterbox) I'm not saying it has to be the ecu though. You could be getting a weak signal somewhere causing the fuel to cut when a certain voltage is reached. My friend had something similar I'm going to ask him what it was on his 300M that caused it. (Damn Chrysler)
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM. 18 Inch chrome rims In closet AEM Fuel Rail, SS Lines, 1997 TSI AWD Diamonds Are 4Ever 12.7 @ 107 http://i83.photobucket.com/albums/j2...y/DSC00461.jpg |
yea even in neutral... but not all the time, both times the car was on today and it didnt do it... but other times it will do it often
Im willing to bet you have a real bad boost leak somwhere.. do a boost leak test.. ..also could be your mas airflow sensor....just for shits and giggles try unplugging it and rev it up slowly in nuetral .. see if it will let u get past the 3k..
Def. sounds like the ecu to me. Although it could be bad distributor, jsut a suggestion. The MAF would probably throw a light on.....um....relays and fuses?
Not a boost leak...ESi.
Kris 2012 Genesis Coupe 2.0t |
His car isin't turbo and doesn't have a MAF sensor. It has a MAP sensor on the manifold. It doesn't have a distributor either, electronic ignition. This is a very odd problem, I would think it would either have to be a sensor bad or the ECU. If a sensor was bad it should throw a CEL. Do you know anyone that might have an ECU you could swap with just to rule that out?
I meant the ignition box.
Fuck me! LOL, yeah the ignition coil should be checked. I would also check to see if you might have some oil in your spark plugs.
