Go Back   Automotive Forums Car Chat > Plymouth > Breeze
Old 04-20-2008, 10:25 PM
carhodge carhodge is offline
tach/odometer?
I just got a breeze from my aunt,seems good,underpowerd,but very good on gas.Well the od and tach work only part time.Whats up?and how can I fixit..thanks
Old 09-30-2009, 08:27 PM
Starflare5 Starflare5 is offline
Wink Re: tach/odometer?
Hi there,
I think Imight be able to shed some light on this subject....
As far as the dash goes, and as far as most digital dashes of the late 80's and early 90's, or, at least, their digital parts, these dashes were no different in the solder joint failure area. This actually should have been a recall considering the number of vehicles it affects including the Plymouth Breeze, Dodge Stratus, Chrysler Cirrus and Siebring, but, unfortunately was not for a couple of reasons:
First of all, most vehicle BCMs were designed by this time to store the vehicle's milage instead of the dash cluster storing it. GM even took this one step further by making the cluster error out if it appeared that the milage was in an attempt to be tampered with. Moving on... If you notice, everytime your cluster comes back on from going out, the milage has changed, so Chrysler saw this as a "no harm, no foul" type of situation.
Secondly, Chrysler did not make a recall on this because no one was ever killed in a vehicle due to the odometer and/or tachometer not working. It was considered just an annoyance, and not a safety concern unlike the parking brake and floor shifter.
With that said, if you take the dash to a Chrysler, they will charge you for a whole new cluster, or at least the repair.
Best advice for this is to do 1 of 2 things: 1: If you have about 2 hours of free time, go to your local Radio Shack and pick up a pen soldering iron meant for electronics and a tube of the thin electrotek rosin core solder. Also, if you don't have it, get a multi head torque screw driver, you're going to need it and follow these instructions.
DO NOT get or use a high powered soldering iron for this can damage the board and/or components.
Remove the dash top and remove the cluster using a simple phillips head screw driver, and take the cluster apart using the torque driver.
Remove the backboard, and the front plastic window and cowl, and unscrew and remove the just the speedometer, tachometer, and odometer combo panel.
On the backboard, go ahead and first re-solder every place where it looks to have a component making contact with the board via the solder. most of this will be done on the bulb side up side of the board, but, if you wish, you may also re-solder the loop-connections on the other side of the board as well. This is a very simple, but tedious task and can take an hour.
On the back of the combo panel, re-solder every contact point or solder joint behind the florescent display as well.
Then, simply re-assemble your panel and voila. Your instrument cluster is working once again as if it was brand new or better. This also gives you a chance to clean the cluster inside and out if it has become dirty.
This method will cost around $10.00 or less to do.
2: You can take the cluster to an electronics repair shop which may cost you up to $100 at least.
DO NOT replace the cluster with one from a junk yard or ebay for you may be right back in the same situation. This way, you know it's fixed atleast.
Hope this helps,
Starflare5.
