Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 04-20-2008, 08:40 PM
dormer55 dormer55 is offline
cruise control tower broken
the speedometer cable is conected to the tower which then runs through the firewall. im guessing this is the cruise control? my cruise is broken and was wondering if it is easy to remove this tower?
Old 04-20-2008, 09:38 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: cruise control tower broken
What year is your car? If the cable broke inside the cruise control head (the tower you refer), chances are it's because the control head itself jammed and will need replaced (if you want cruise) or removed (if you don't). In the event of the latter, you can run a speedometer cable right to the transmission, but consider the possibility that you will have to pull the tailcone off the trans to replace the speedo drive gear (and driven gear too), as they're likely stripped. I went through this on my old '82 Impala.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 04-20-2008, 10:03 PM
i have an 81 caprice, 305 v8. with the 200r4 tranny
