Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 04-20-2008, 03:49 PM
spsvrman spsvrman is offline
2001 Yukon idling fast and check engine light only on for very short time
Hi all,
2001 Yukon XL runs very well but idles park around 1000 rpm and the check engine light comes on, but not long enough to get it any where to have it checked. This has happened a few times in the past couple of weeks. I have cleaned the throttle body and the MAF out with no luck.
Any help would be appreciated.
Old 04-21-2008, 12:30 PM
2000CAYukon 2000CAYukon is offline
Re: 2001 Yukon idling fast and check engine light only on for very short time
Did you get it scanned? Even if the light is out, there should be a history of codes set.
Look for any cracked, broken or disconnected vacuum lines. A high idle can be a vacuum leak.
//2000CAYukon
Old 06-05-2008, 11:35 PM
bungnati bungnati is offline
Ive replaced the Idle Air Control Valve on my 2001 because it would get stuck slightly open and idle fast. I drove it around the block to get it to re-seat itself.
Old 06-16-2008, 06:26 PM
bungnati,
Thanks for your reply, where exactly is the Idle Air Control Valve ? Any help would be greatly appreciated.
Old 06-16-2008, 06:50 PM
Originally Posted by spsvrman
bungnati,
Old 06-17-2008, 06:44 AM
Thanks,
Is there any chance of taking that IAC out and cleaning it up ?
Old 06-17-2008, 09:02 AM
Thanks,
Its pretty easy to take out. Just unclip the wires and remove the 2 torx bolts holding it in. I dont remember what size they were tho. You should be able to use some mild cleaner on it and the seat.
