Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 04-20-2008, 11:28 AM
Gm_geezerII Gm_geezerII is offline
Removed battery now lots of problems
Just looking for a little guidence to understand what just happened.
05 Montana US Base.
First I was replacing the dash cluster with an e-bay pruchased cluster. (the original was ka-put).
I dissconnected the battery. Repalced the dash. And reconnected the battery.
Now the SIRS lamp is always lit and the radio (RDS unit) is locked.
Did I fry something or does this vehicle lose its mind when the battery is dissconnected?
Will this happen every time the battery is dissconnected?
Old 05-05-2008, 11:58 AM
truc0011 truc0011 is offline
Re: Removed battery now lots of problems
05 Montana US Base.
The cluster has to be programmed to the van, you need to have a tech 2 gm scanner/programmer to do this. Else you need to bring it to the dealer and have them do it.
Old 05-05-2008, 12:27 PM
rockwood84 rockwood84 is offline
did you try and reprogram it ? they do lose their memory when the battery is unhooked for a couple of days.your owner's manual has the steps in it to reprogram it.
Old 05-05-2008, 01:19 PM
I disagree that they lose their programming when the battery in unhooked for a couple days. When I installed a transmission I had my battery unhooked for 2 weeks and the programming was not lost. In fact the radio station presets were still in the radio.
Old 05-05-2008, 01:23 PM
I once put in a used cluster in my Montana and I got the same results that you described here, I then put the old cluster back in and everything worked fine. I talked to the dealer and they told me that the cluster has to be programmed. Give your dealer a call to verify, or you could try putting the old cluster back in just to verify that the original would clear out the problem.
Old 05-09-2008, 03:49 AM
maybe yours had a better brain
Old 05-11-2008, 09:39 PM
Thanks for the replys.
Where I am at now. The better half took it to the local dealer and they got the radio going no charge.
Now the air bag lamp is still light. Onward and upward.
