Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 04-19-2008, 08:43 PM
vinsanity73 vinsanity73 is offline
Driver side window off track
mechanically everything works(regulator, motor, etc), what keeps the glass in the regulator? I've seen an $11.00 part called a "retainer", and if there's adhesive to be used also ,what kind? Simple fix, just need some direction.
Old 04-19-2008, 10:14 PM
Towncar's Avatar
Towncar Towncar is offline
Re: Driver side window off track
So, it's a 1996 !!! I was thinking it was older for some reason.
«1996 Continental Table of Contents»
«Group 01: BODY»
«Section 01-11: Glass, Frames and Mechanisms»
«DESCRIPTION AND OPERATION»
Window Glass, Door
The bottom of the door glass is mounted on a slider bracket that is part of the window regulator mechanism.
Snap-in nylon inserts provide attachment points for the glass and prevent direct contact between the glass and the slider bracket (rear door only).
Mike should be able to confirm.. it looks to me that the glass has two mounting holes near the bottom that get secured to the regulators... or maybe that's only the rear doors/glass ???
Here are the rest of the R & R procedures from the FSM:
< 1996 Conti Door Glass >
< 1996 Conti Door Regulators >
< 1996 Conti Door Top Runs >
-Steven
1996 Town Car, Cartier
