Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 04-19-2008, 07:42 PM
Domestics_Only Domestics_Only is offline
Driverside window wont go up or down
For awhile now the window was going up slowly, and it would tilt forward eventually coming to a stop, then i would have to tilt it back, and continue to raise up the window, but now it doesn't want to go up or down i don't mind replacing everything but what should i be looking at replacing??
2002 GTP - My Baby
1999 Chev Venture - Beater - 2 problems down 1 to go (Rear wiper motor)
Old 04-19-2008, 07:49 PM
meggabad meggabad is offline
Re: Driverside window wont go up or down
The window regulator and motor. Autopartswarehouse has pretty decent prices if you dont mind waiting a week for delivery from CA, just did mine.
Old 04-27-2008, 10:37 AM
i took some good spray lub and lubed the felt looking guides and its runs 100% better, onlything its doing now is when i put the window up its tilting forward...
2002 GTP - My Baby
Old 04-27-2008, 10:41 AM
venturenot venturenot is offline
What type of lube did you use?
Old 04-27-2008, 11:08 AM
just some mulitpurpose spray lube from Canadain Tire it goes on thick but absorbed into the guides and now its like silk minus the tilting action
2002 GTP - My Baby
Old 04-27-2008, 01:06 PM
Does it have a silicon base?
Old 07-19-2008, 08:32 PM
base1hits base1hits is offline
I had the same sticking / tilting problems with my drivers side window on my 2000 Venture. Silicone based spray ($4 from Autozone) applied liberaly to the guides all around fixed the problem very well. I'm told that non-silicone based lubes won't work. I plan to reapply again if the window acts up.
Old 07-21-2008, 05:39 PM
cjstew4 cjstew4 is offline
Probably a WD-40 or similar. You need the one that says silicone and re-soak the s*** out of all the vertical felt guides to the point that both sides of each felt guide receive it. Also have someone operate the up/down toggle while you press and aid the window to not tilt forward. Try to push the window slightly in and out as it goes up so that you try to ensure both sides of the window receive the lube from the felt. After a few of these it s/b fine. If not spray the edges of the window. Wipe of excess, etc after you get the tilt out. Good luck.
