Old 04-19-2008, 05:36 PM
nico520 nico520 is offline
Help please - oil leak and headlights don't work
I have two problems I have a 96 taurus wagon and its leaking oil from behind the wheel that spins the belt and my headlamps wont come on I had everything checked and they could not find out y the dont work
Old 04-19-2008, 06:40 PM
inafogg inafogg is offline
Re: Help
HELLO,the only pulley that can leak oil behind it is crank pulley.the only pullies that are left are idler & tensioner.as far as i no only solid block behind them.NOT SURE OF WHAT ENGINE.the rest are acc. pullies!! & i'm not to sure you jacked up removed covers to inspect crank seal.what pulley are u talking about???
Old 04-20-2008, 09:48 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Help please - oil leak and headlights don't work
Welcome to the forum!
I changed the thread title to something meaningful per the forum guidelines you agreed to when signing up for your account. Please keep these guidelines in mind for future posts.
It's doubtful the two problems are related. I agree with inafogg that the oil leak, if it's coming from a pulley, would be the crankshaft pulley. As he mentions though, without knowing which engine is in your Taurus, it's difficult to guide you to known oil leak sources.
Are you quite certain that the oil isn't leaking from somewhere higher and draining down, then dripping from the area of the crankshaft pulley since it's at the lowest point (pulley-wise) of the engine? There are dye leak detection kits that could greatly aid in determining the source of the oil leak.
As for the headlights, have you checked the fuses for the lights? Do any of the lights work when you turn the headlights on such as the parking lights or interior instrumentation lights?
-Rod
Old 05-27-2008, 08:35 PM
metonic metonic is offline
headlights... can you flash your brights? I currently have a problem where once i na while my headlights stop working, my brights stop working and all i can do is flash my brights. Some times the lights work, sometimes the brights work, some times they both work. My problem, as I understand is the multifunction switch(turn signal switch) I have a 98 taurus LX though, so Im not sure if yours would have the same problem. Anyway, to replace it go to Autozone. Its 72 bucks there, while every other store seems to cost 85 to 190. Used can cost anywhere from 30 bucks to 80 bucks. For those prices I would go with a new one.
