Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 04-19-2008, 02:57 PM
GreyGoose006 GreyGoose006 is offline
trunk popper
How much power should be sent to the trunk popper?
i just yanked one off a car from the junkyard.
im guessing that it needs 12v but i dont know how much current it can take without damaging the solenoid.
anyone feel like taking a measurement for me?
thanks
Old 04-19-2008, 05:22 PM
mike561 mike561 is offline
Re: trunk popper
I diddnt even take a measurement, i just hooked it right to the 12 volt batt source and it worked fine, however i was told i should probably put a fuse between the wire, forgot which amperage though. then i just got a basic toggle swich from advance auto and put it in my glove box. im geussing you took one from a 9C1 right? thats where i got mine from, it fit right over the bracket i already had
2006 Chevy Cobalt LS
Old 04-20-2008, 01:20 AM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Re: trunk popper
I got mine from a civi Caprice. I took the OEM switch too that goes down on the lower part of the driver's side dash. A constant 12V source with a 10 amp fuse worked like a charm. I even wired it to my keyless entry system.
Old 04-20-2008, 08:16 AM
Re: trunk popper
i snagged it from a civvie caprice. like a 89 or so.
it was newer than mine, which is 84, but older than the ones with the single headlights and new lght piece.
i will hook it up to a 5-10 amp fuse i guess.
Old 04-20-2008, 10:52 PM
Re: trunk popper
were your cars wired for a trunk popper?
i just realized that i would need to run a wire from the trunk to the dash...
blond moment.
so im guessing i have to take out the back seat, lift up the carpet and drill a hole in the dash.
anything else?
how did you go about it?
Old 04-20-2008, 11:33 PM
PeteA216's Avatar
Re: trunk popper
Yup... I had to wire it myself. Under the carpet, behind the back seat and through the insulation. I didn't need to drill any hole though. I just used the already existing opening behind the seat. Tucked everything in nice so nobody knows thew wire's even there. I soldered and heat shrinked (shinked, shrunk... whatever) all my connections to make sure there wasn't ever gonna be any failed connection or short. It wasn't too hard. On a difficulty scale of 1 to 5 I give it a 1 1/2.
Old 04-20-2008, 11:56 PM
Re: trunk popper
i mean drill a hole to put the button in the dash...
Old 04-20-2008, 11:57 PM
Re: trunk popper
the bottom rear seat just pops out if you push on it right?
i seem to remember hearing that it does, but im not sure.
well its gonna be a cool project to keep me busy i guess.
what with school and all.
Old 04-21-2008, 09:11 AM
PeteA216's Avatar
Re: trunk popper
The button (or switch) I got was sort of a slider kinda push down style switch. It was black with a little white picture of a car with the trunk open on it. Since the OEM hole was rectangular for it, I drilled a hole and carefully used a razor blade to shape the hole the rest of the way.
Old 04-21-2008, 10:18 AM
Re: trunk popper
i just got a momentary button to put near the ashtray area.
i could put it there or in the footwell, but i dont want to pop the trunk while driving...
Old 04-21-2008, 11:04 AM
PeteA216's Avatar
Re: trunk popper
Even though I didn't do it this way, I believe that technically the power is supposed to be run through the neutral/park switch so that while the car's in gear, the trunk can't be popped.
Old 04-21-2008, 02:00 PM
Re: trunk popper
I wanted to do it that way but i'm not too electrical savvy so i just put it in the glove box, i'm also working on trying to rig up a light on the dash that comes on when its open, there is a light lense that says "T-Gate Ajar" on the temp guage thats not used, i think ill put it on that one.
Old 04-21-2008, 02:10 PM
Re: trunk popper
i was thinking about getting an LED to tell me if it was open while i was at radio shack, but couldnt figure out in my head how to do it effectively, so didnt.
what color is the neutral/park switch.
is there even one on my car?
i can put the car in whatever gear i want without my foot on the brake, which is odd IMO.
Old 04-21-2008, 02:51 PM
Re: trunk popper
mine is like that also, i think only newer cars have that feature where you press the brake first to shift, its a safety thing
Old 04-21-2008, 11:21 PM
PeteA216's Avatar
Re: trunk popper
Correct. And these cars do have a gear positioning switch. It's neccesary to keep the starter from cranking while the transmission is in gear. Now if I only knew where it is.
Oh and BTW my car has the tailgait light too even though its not a wagon. I think they just made up a bunch of the same instrument panels so they could just all e throw into the car regardless of if its a coupe, sedan, or wagon.
