Old 04-19-2008, 11:33 AM
dreamweaver47 dreamweaver47 is offline
air condition blows hot air
I need help with my 1995 S-10 blazer , my air cond. blows hot air I removed the fuse for a/c and heater , unpluged the fan and it still blows hot air by my feet what could be causing this
Old 04-21-2008, 10:49 PM
ksubenny ksubenny is offline
Re: air condition blows hot air
Assuming that the AC worked before it likely means that you have a leak in the system or your compressor isn't kicking on. With the car on, pop the hood and turn the AC on, you should see/hear the AC compressor clutch kick on. If it does kick on its likely your low on 134a and it needs to be recharged and then trace the leak.
Old 04-22-2008, 08:32 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Heater not switching to vent or defrost.
If it is not switching from floor to vent or defrost.
Check for good engine vacuum to heater controls.
A lot of problems with the plastic and rubber vacuum lines and at vacuum tank.
MT
MT
