gasoline saving tips
i found this on the net and it is what i agree as a way to get the most when refueling vehicle.. ...
I don’t know what you guys are paying for gasoline.... but here in California we are also paying higher, up to $3.50 per gallon. But my line of work is in petroleum for about 31 years now, so here are some tricksto get more of your money’s worth for every gallon.. Here at the Kinder Morgan Pipeline where I work in San Jose , CA we deliver about 4 million gallons in a 24-hour period thru the pipeline. One day is diesel the next day is jet fuel, and gasoline, regular and premium grades. We have 34-storage tanks here with a total capacity of 16,800,000 gallons. Only buy or fill up your car or truck in the early morning when the ground temperature is still cold. Remember that all service stations have their storage tanks buried below ground. The colder the ground the more dense the gasoline, when it gets warmer gasoline expands, so buying in the afternoon or in the evening....your gallon is not exactly a gallon. In the petroleum business, the specific gravity and the temperature of the gasoline, diesel and jet fuel, ethanol and other petroleum products plays an important role. A 1-degree rise in temperature is a big deal for this business. But the service stations do not have temperature compensation at the pumps. When you’re filling up do not squeeze the trigger of the nozzle to a fast mode. If you look you will see that the trigger has three (3)stages: low, middle, and high. In slow mode you should be pumping on low speed, thereby minimizing the vapors that are created while you are pumping. All hoses at the pump have a vapor return. If you are pumping on the fast rate, some other liquid that goes to your tank becomes vapor. Those vapors are being sucked up and back into the underground storage tank so you’re getting less worth for your money. One of the most important tips is to fill up when your gas tank is HALF FULL or HALF EMPTY. The reason for this is, t he more gas you have in your tank the less air occupying its empty space. Gasoline evaporates faster than you can imagine. Gasoline storage tanks have an internal floating roof. This roof serves as zero clearance between the gas and the atmosphere, so it minimizes the evaporation. Unlike service stations, here where I work, every truck that we load is temperature compensated so that every gallon is actually the exact amount. Another reminder, if there is a gasoline truck pumping into the storage tanks when you stop to buy gas, DO NOT fill up—most likely the gasoline is being stirred up as the gas is being delivered, and you might pick up some of the dirt that normally settles on the bottom. Hope this will help you get the most value for your money. |
Re: gasoline saving tips
Great info. Thanks
A lot of that info is debatable and there are better ways to save on gas and get better fuel economy. That has been circulating around the internet for quite sometime and I get a copy of this in my email inbox practically every week.Check out this link to see the real facts behind the claims:http://www.snopes.com/inboxer/household/gastips.asp
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. ![]() If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
Something else no one seems to consider... NEVER use a "drive through". Your car gets ZERO MPG while idling. It also makes more emmissions at idle than at any other time.
Jim |
I didn't mean to seem insensitive to those with special needs. I fully understand if you MUST do something a certain way. My focus is for the vast majority. I haven't used a drive-thru in years... My decision was based on emmissions, not fuel economy. It just happens to "work out that way"...
Jim |
Another note to Jim's reply concerning drive thrus. They can be a timesaver in some situations. For example you have to deposit a check or something quick at the bank and there is a long line inside. Generally one would think you could zip through the drive thru and deposit it and be done in no time. But many times there's someone who's inconsiderate or unprepared and holds up the whole line. Those drive thrus are there for the convenience of the customers and if you're not prepared,( as you should be before going through one as directed by the many signs present, ) or don't know exactly what you're doing, then go inside to handle your business. Let those who are prepared go through with ease instead of holding everybody else up. I guess the same thing could be said for fast food drive thrus. Be prepared with your order and know what you want and don't make the order too complicated to slow the line down. (end of rant
Take a lesson from Europeans and Asians, and turn off your engine at stoplights and in drive-through lanes. Idling for about 15 seconds wastes more fuel than stopping and starting the engine.
Use fully synthetic (PAO/Group IV) lubricants. Chassis dynamometers have proven an increase in wheel horsepower of 10% by simply switching to PAO synthetic lubricants in the engine, transmission, and differential. That's most likely due to the decrease in friction resulting from the superior lubricant. It might not have been worth it for you before, but with fuel at $4 a gallon, and mineral oil costing $3 a quart, synthetics are actually becoming a bargain in many ways, since you can usually safely run it longer than mineral oil, saving fuel all along the way. Keep tires at the appropriate maximum inflation. Under-pressure tires increase rolling resistance in a fairly asymmetrical manner, but most tires don't actually appear to be low until they are at least 50% below proper inflation. You need to actually check pressure at least once every month, and DON'T rely on the factory "tire pressure monitors" since they don't really measure tire pressure, but count the number of revolutions of one tire compared to another. They necessarily allow very low pressure before turning on. Keep the tires inflated, and save in both fuel and replacement tires. Maintain alignment. 1/8" of improper toe can impart a force equal to an additional 60' of distance in every mile traveled. While that doesn't sound like a lot, it equals 1.15% in mileage, and you would barely even notice unusual tire wear with that little toe change. More severely misaligned vehicles can lose up to 10% mileage, not to mention the rapid wear of tires and vehicle parts. If you have noticeable tire wear, you can save fuel money by having the alignment corrected. A $39.95 alignment special might save you that much in the first month alone. Again, there are no computer error codes for poorly aligned wheels, so you'll actually have to get out of your chair and do something. Keep a clean air filter. Paper elements may look "clean" but still have restriction, since the filter media entraps the smallest particles first. Testing pressure drop over time indicates the greatest drop in pressure at the beginning of a filter's useful life, and a slowly tapering increase after that. Operate the engine at the highest safe temperature. Change back to a stock 195ºF thermostat if that's what your vehicle was programmed to use (as in most of them since the 1980s). Fuel trims are based on the engine reaching proper temperature. If the engine is overheating, don't just put a band-aid on it by installing a colder thermostat, but address the actual problem. You can clean the cooling system, install an adequate water pump and radiator, and/or reprogram the PCM for the temperature you're running. Use a higher quality oil filter. Low quality filter media creates a higher differential pressure across the element, making the engine work harder from idle to cruise RPM, and wasting fuel all the while. AAA reports an increase of up to 23 more miles on a tank of fuel by simply using a good oil filter. Installing a $4 orange filter might cost you a lot more in fuel than the "savings" by not using a $7 good oil filter (a.k.a., NOT orange). Make sure the fuel tank is sealed. Having a fuel tank cap in good order can prevent the evaporation of up to 17% of the liquid fuel in the tank over the course of a week. Pollution aside, in warmer weather you can lose 1/6 of your tank to evaporation. For a 18 gallon tank, thats $12 a week going up in vapors, never to be recovered. Spend that on a new fuel cap if your's is missing, or repair the EVAP hoses and start saving. If you feel guilty, you can all send me $12 a week after that until you feel better about yourselves. Maintain your vehicle tune. If the "Check Engine" light is on, you might really want to get that checked. It might be as little as a leaking fuel cap (see above) or misfiring ignition, injector problems, slipping transmission, or any of a number of other small and easily solved problems which could be costing you $$$ in fuel.
Permanent seat assignment on the Group W bench... Automotive Forums Survival Guide |
Add to that something else I just read recently. Make sure your tires are properly balanced as well. A tire that is not balanced properly does not ride smooth and causes extra friction or drag on a vehicle, thus lowering your fuel economy. For the minimal cost of having your tires checked to see if they are properly balanced, ( those little lead weights can and do come off sometimes,) you can recoup what you spend on that service by your savings in gas over a short length of time.
http://water4gas.com/2books.htm?hop=drivewater
This is something that caught my interest. Has anyone ever tried something like this? i am thinking about doing it to my lawnmower and if it all goes right i might try it on a car.
Brains are funny, You shake them around and its like whoa whos driving this ship.
Honestly a renewable fuel source is what we need. Something like the biofuels or water would be great. The biofuels I have been learning about and also considering on trying to make some for my diesel truck has really drawn my attention, I have even considered on making my own moonshine still and making ethanol. Only downside to the ethanol for my gasoline vehicle is I readyou need to files a bunch of paperwork and permits to the ATF. I also read that if permitted to make yor own ethanol you need to add a certain chemical to make undrinkable. The more I have read up the government has the hands in there somewhere, biodiesel can only be made up to 400 gallons, anything after that you need to pay road taxes on it. Of course I would probably never make anywhere close to that, I am lucky to need 30 gallons in a months time. Ethanol is another thing, I have not done a lot of reading on that but speculate the permits probably cost money allowing you to set up your own moonshine still/ethanol maker. May be cheaper just irritating knowing the government has to have their hands in there somewhere, most likely what is driving the cost so high at the pumps now. If more people would actually try alternative methiods maybe the actual prices at the pumps would come down though. |
