Old 04-18-2008, 02:56 PM
btestacct btestacct is offline
All Time Heat
My son's 99 Jimmy has excellent heat. The problem is it won't turn off. Air direction is not a problem as he can direct the heat to any location. Adjusting the temp setting does not change the temp. I removed the knob and verified that the switch was turning. Since I have heat I assume (maybe incorrectly) that it's not a clogged heater core.
There is also a clicking noise coming from the area of the glovebox/airbag. I don't know if it's connected to the heat issue, but wanted it to put it in the post.
Thanks in advance! It's 75 degrees here and with the heat on high I need your help.
Old 04-18-2008, 04:55 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: All Time Heat
Automatic or manual controls.
If automatic remove glove box on see if the clicking is coming from the actuator motor on top of ac/heater box.
Up in the how to there is some pictures and info on it.
MT
MT
Old 04-18-2008, 05:13 PM
MT-2500's Avatar
AF - Advisor
Re: All Time Heat
This link here in how to section.
http://www.automotiveforums.com/vbul...d.php?t=574779
MT
